has any one hear of linning up the numbers on the primary gear to the clutch gear? also does the nut on the primary gear have a standard thread.right tight left loose also when i install my clutch i was told that the plates that go in between the fibers have a sharp edge on one side and i am to put them all in thr same way. witch way is right facing into motor or out towards case cover. i am having a problem with the bike going forward when i go to take off for the first time after i drive it a while it stops also i adjusted the screw in the center of the hub but im not sure if i did it right. do i push the lever on the top of the case towards the clutch side of the bike. ounce it is set right should i only be able to push as far as the arrows line up then the lever will pull from there???
I NEED HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!
The numbers are lash numbers,lining them up won't do anything.the gear is right hand thread.as for the plates I've never looked for a sharp edge I install using the machined circumference stagered as outlined in the manual.and as for the rod adjustment I adjust the screw to were it is JUST shy of the arrow on all of mine.
word :baseball_w00t:
