Sunday I blew my motor. Rubber intake boot cracked sucked in air and there goes my right piston!
I took it apart today and a tiny piece came off and and went out the exhaust...So it seems. there are no scratches whatsoever in the cylinders, and I found out I have a Hotrods Crank in it. :beer:
Since I already got the crank what do I need to make a 4mm stroker.
A complete hot rods +4mm stroker crank.(I think you might need special pistons for the stroker crank as well)
The plate that goes betweent the cylinders and cases, or cut domes for the stoker.
Porting to take advantage of the different port timing that the stroker creates.
