slow2_2 Posted July 31, 2006 Report Posted July 31, 2006 What type of oil do you recommend for improved shifting. I would rather hold off on splitting the cases until I really need to. So for now I'm just wondering if there was an oil that you have found to help with the shee shifting problem. I'm not asking for perfect, just better. Quote
Snopczynski Posted July 31, 2006 Report Posted July 31, 2006 yah gear saver Maxima MTL endurance Quote
Hilarious Posted July 31, 2006 Report Posted July 31, 2006 What type of oil do you recommend for improved shifting. I would rather hold off on splitting the cases until I really need to. So for now I'm just wondering if there was an oil that you have found to help with the shee shifting problem. I'm not asking for perfect, just better. You dont have to split your cases. That is assuming that your are thinking about the shift kit or modded shift star. Just pull the clutch cover off. And I think you will have to pull your clutch basket too. Not a hard task at all. I use maxima mtl 80w and works pretty good. :beer: Quote
2stroker4ever Posted July 31, 2006 Report Posted July 31, 2006 AMSOIL 10w40 for me, works like a charm. Quote
