I had it running checking jet size. it was ideling then died. will not start back up. I got a new cdi, stator, plugs, rebuilt top end, changed jet sizes. everything I can think of. There are no leaks air or fuel. I checked the spark and shocked the shit out of my buddies hand. I pulled the carbs and they are getting fuel. Im out of Ideas. If anyone knows what I should try please let me know. I would like to get it running before I move back to the states but if I dont does anyone know of a shop or someone who could help me out around New Mexico. And Jim if you have any ideas please let me know
is the choke tube on between the 2 carbs?
i second checking your reeds. whether they are stuck open or shut, it will not run properly.
ill check into it but it will not start at all much less run right. and it did run but died and will not start back up
Have you checked all the wires to make sure you dont have one grounding to something or each other?
After you kick it pull the plugs and tell us wether their wet ,dry or what.If its getting fuel,fire and has compression it shold atleast try to run.It sounds electrical to me.
I jsut put new pluggs in today. It is getting fuel, air and belive me it is getting spark. ask my friend lol, The compression is good. This is why as far as electicla goes... New stator, plugs and cdi. Tors is unplugged.
Not trying to be a smart ass...but how do you know the compression is good?
Did you use a tester for it?
Also...might be time for a leakdown test.
I have to agree ive seen very few motors that are getting fire fuel and compression that will not hit a lick.Ive seen some that wont idle or run worth a damn but the plugs will lead you to the problem.
