watkins Posted June 24, 2006 Report Posted June 24, 2006 Scratching my head here... got a pancake bearing from Passion and dont really know how to install this thing.... it came with all the proper parts, but I just dont get how to put the bearing assembly together.... maybe its just too late in the evening for me... anyways here is the pic of how i think its supposed to be setup.. please chime in. THanks. Quote
FireHead Posted June 24, 2006 Report Posted June 24, 2006 Do a search. There was a really good post on this a few weeks ago. :baseball_bat: Quote
hittintrees srh Posted June 24, 2006 Report Posted June 24, 2006 got the same setup from f.a.s.t.- it goes -pressure plate -washer -bearing -spindle make sure to grease the hell out of the bearing as well as the ball and shaft if im wrong someone please correct me. Quote
sheefreak Posted June 24, 2006 Report Posted June 24, 2006 You know you still have to use the ball also right? Quote
watkins Posted June 25, 2006 Author Report Posted June 25, 2006 got the same setup from f.a.s.t.- it goes -pressure plate -washer -bearing -spindle make sure to grease the hell out of the bearing as well as the ball and shaft if im wrong someone please correct me. Worked perfect, thanks. Quote
watkins Posted June 26, 2006 Author Report Posted June 26, 2006 Good luck on the tightening. There was actually a good topic about that I found... worked perfect.... wasnt too much of a pain to tighten. Quote
broke Posted June 26, 2006 Report Posted June 26, 2006 Probably my topic, It messed with me for a long time. Quote
watkins Posted June 26, 2006 Author Report Posted June 26, 2006 Probably my topic, It messed with me for a long time. Just went back and checked.. yup.. it was your thread... thanks for the indirect help :biggrin: I would have been scratchin my head for a while trying to figure that one out . Quote
