:baseball_bat: i've seen all kinds of yfz's beat up on banshees
It happens all the time.... people just don't like to admit it...
Oh yeah, and the bog off idle can be fixed by changing your leak jet from what I've read. It's a common problem and I still have it on mine....you can make it better by tweaking the pilot jet and fuel screw. I really don't even notice it much anymore :shrug:
After you buy the bike, check yfzcentral for the "known" problems on the 06's. There are a few little things you'll want to pay attention to on those new 450's.
Travis, the bog off bottom is b/c the fcr carb AP spring is a little too long.. thus when you nail the throttle off idle it shoots it too much fuel for the motor... It can be cured with about 30 mins of carb work...
IMO the honda 450 is the one to beat right now.... The suzuki rarely finishes a race and the yfz is a moody bitch... Basically honda upgraded and got it right... yamaha tried to be shisty about it and it screwed them in the end...
Mike
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
The best setup that I have seen is a curtis sparks big core exaust, curtis sparks air filter adapter plate(if you run a foam filter)and a curtis sparks foam filter. I did the cam mod on mine and noticed a big difference.This will do pretty good if tou like to trail ride and minor drag racing. If you want to drag race without spending a ton get you a +6 swing arm, toss the stock carb in exchange for a 41mm lectron carb to run alky.With this setup I was outrunning stock bore 13 to 1 comp hondas with port work and swingarms. I now have a ported head stock piston on a drag frame and it runs with a big bore, stroked ,and ported head honda with a cam. If you change the cam go with the ron woods for the most difference. For port work I got jeremy from finishline racing to work it up for me. Hope that helps. We did try the ron woods pipe and it wasn't bad but we liked the sparks pipe better.
Ya, my brother runs a white brothers pipe and K&N, and that little shit is pretty quick. He gets out ahead of me off the line about two lengths and then I hold him but by then he is already ahead. Wait til I introduce him to my 421 cubby. muhahahahahahah :evil:
My YFZ 450 set up is an HMF full sport system cam-mod (with the YZ-450-F cam installed) GYTR ,CDI
K&N pro flow, jet kit, zip ty fuel screw, maby theres something I'm missing but other than the stuff needed for racing like My AC nerfs GYTR bumper, RENTHAL bars and grips Billet brake and shifter, ITP holeshot mxs on the way same as K&K graphics and soon I'am cutting the fenders and a kill switch. and port & polish 13:1 high comp piston and hinson clutch kit and in the future ELKAS , LEAGER A-arms and swing arm lonestar axel and other than the stuff I hav and the stuff I plan on doing thats all. I am getting a Banshee soon though.
YES DO THE CAM-MOD ALOT MORE TOP-END.
Finally got it broke in today. Changed the oil for the first time then went for a short ride. I have to say i'm pretty impressed with the power it has even in stock trim. Talked to Jeff at F.A.S.T and got me a Sparks pipe coming soon! Think i'm also gonna so with the velocity tube intake. Looks like it would be pretty good. Then i'll probably do the cam mod within the next couple weeks. Any other small things I should do that you guys can think of?
