Ok I have a 2001 banshee. Total rebuild almost done, will be complete when I trade off or sell.
Frame and +6 swing arm painter Yamaha R1 Blue, a-arms, tie rodes, and steering stem all chrome, Fullbore front fenders, All extreeeeeemly clean. Every thing has been painted polished or chrome... Frame has been striped and lightened of all the BS brackets for a clean look..
Now for the good stuff. MOTOR
421 Cheetah Cub 4mil Stroker BRAND NEW!! Never Run Yet. I just got the motor back 2 days ago and have not even taken it out on the 1st ride yet.. HotRod 4 mil stroker w/ 5 mil Long Rods True and welded with HEAVY DUTY TZ bearings installed. Cases have been portmatched, lightened flywheel, Noss Machine head w/ special cut domes for 68mm bore. The motor will be 100% completely rebuilt with all new parts and seals. Have reciepts for every thing that goes on or in motor. The head will produce almost 185 psi of compression per cylinder.. 110 octane only..
Exhaust BRAND NEW CPI InFrame Drag Pipes CHROME.. Custom made heat wraps for stingers. Cascade Billet NO LEAK exhaust Clamps.
Intake Brand New 35mm PWKS Clamp on Style K&N Filters w/ angle to clear exhaust pipes, Outter Wears UPP intake boots from carbs to Cylinders. Brand New V-Force III reed valves Adjustable timing plate set at +4
Chain and Sprockes... 100% the best you can Buy.. Sidewinder Ti-Moly 17/42 gearing
Honestly there is soooo much stuff I have bought for this bike I can not remember. Brand New Douglass wheels front and rear, ASV Clutch lever, new cables, new chain guide, new bearings for swing arm, and new bushings in a-arms.. Too much to list
Every thing said and done This bike will have close to 95HP... I have almost $5000.00 invested in this thing. And have a ton stock parts... I will post some pics. shortly..
I am ASKING $4500.00 I am in Lufkin Tx. and I would perfer pick up, but I can and will ship if needed. I just put the motor in Last night, I have not added gas to the tank yet. I will get it tuned up by this weekend and running.
Here are some pics. of my progress. Also some more parts that are brand new, front and rear SS brake lines, billet front brake line clamps
[image]http://memimage.cardomain.net/member_images/12/web/804000-804999/804457_126_full.jpg[/image]
[image]http://memimage.cardomain.net/member_images/12/web/804000-804999/804457_125_full.jpg[/image]
[image]http://memimage.cardomain.net/member_images/12/web/804000-804999/804457_124_full.jpg[/image]
[image]http://memimage.cardomain.net/member_images/12/web/804000-804999/804457_123_full.jpg[/image]
[image]http://memimage.cardomain.net/member_images/12/web/804000-804999/804457_122_full.jpg[/image]
[image]http://memimage.cardomain.net/member_images/12/web/804000-804999/804457_121_full.jpg[/image]
[image]http://memimage.cardomain.net/member_images/12/web/804000-804999/804457_120_full.jpg[/image]
Also I may sell just the motor alone for $3000, motor has never been run. If I sell the motor I will part out the rest !!!!
Willing to part out?
I will only part it out if I sale the motor first... Complete BRAND NEW MOTOR 100% all new never even started it up yet, and was built by HRI PowerSports.
421 Cheetah Cubs, HotRod Crank 4 mil True and Welded, TZ bearings on crank, all new seals, cases have been port matched, Noss Head Black anodized w/ 20cc Cub Domes, Lightened Flywheel Timing advance plate all with complete tear down and inspection... No chain brake on the case 100% perfect!!!
$3000 obo for motor alone.
20cc domes at 185 psi really? i have 20 cc domes in my cub and can run pump sounds like u have about the same motor setup
Is the bike complete? If so, if you still have the bike in a couple of days, I'll most likely be interested in the complete bike.
Yes I have every thing to complete 100%. I just have not put it all back together. I am working on that now. Any one with any questions feel free to call 936-676-1179 Sam
Nice bike!! I like the heat wrap on the stingers. What did you do that with? What did it cost you? Thanks.
Got them from cascade atv..
B U M P
I wil sale the motor complete with the BRAND NEW upp intake boots, v-force III reeds, 35mm PWK's, Clamp on Filters, Noss Head, and CPI Pipes for $3250 shipped. FIRM.
If motor Sells I will part the rest out.
