chronicwatson Posted May 31, 2006 Report Posted May 31, 2006 hi i live in southern ontario and have a stock banshee with the snorkel removed. i'm putting fmf fattys on it and want to know what size main jets i should start out with any help would be great. Quote
dajogejr Posted May 31, 2006 Report Posted May 31, 2006 Are you leaving your airbox the way it is, stock filter with the lid on? If so...you'll be around 250 or so on the mains. Middle clip on the needles. FMF pipes like a fat pilot circuit. With the airbox and lid on...you could probably be ok with stock pilots, but you might have to bump up one size (to 27.5 ) with the pilots. If you end up running the air screw .25 to .5 turns out for it to run right off the idle, get bigger pilots. Quote
chronicwatson Posted May 31, 2006 Author Report Posted May 31, 2006 i think i may try a 280 do you think that will be to fat i'm around 700-900 feet and the air temp is around 60-90 f Quote
sheefreak Posted May 31, 2006 Report Posted May 31, 2006 I think you will be fat at 280, especially w/ a foam filter. It won't hurt though, you can always go down from there. I thing dajogerjr is pretty close. Quote
batoutofshell Posted May 31, 2006 Report Posted May 31, 2006 Same pipes as you running 280 main stock pilot, k&n lid off, proflo and outerwears, toomey needles 4th clip. Hope I can help Quote
dajogejr Posted May 31, 2006 Report Posted May 31, 2006 i think i may try a 280 do you think that will be to fat i'm around 700-900 feet and the air temp is around 60-90 f You will definately be safe...that's for sure. I think you'll find cleaner running a little leaner though... Always better to start off Rich....best of luck!! Quote
chronicwatson Posted May 31, 2006 Author Report Posted May 31, 2006 you think i'll be safe with a 260 Quote
dajogejr Posted May 31, 2006 Report Posted May 31, 2006 I think you should spend 20 bucks in jets, get 250 to 270. Start with 260. Spend another 10 in plugs. Look at your plugs...they will tell you. 30 bucks in plugs/jets is alot cheaper than a fresh top end. No one can tell you with 100% certainty you'll be 100% safe. We're just basing it on our own experiences...and trying to give you a guideline. <Insert legal disclaimer here... > Quote
chronicwatson Posted May 31, 2006 Author Report Posted May 31, 2006 well the guy i got the pipes off of lives near me and i asked him what size jets he was running and he said when he put them on he never rejetted and i was like your lucky your bike didn't pop and he told me you need a pro to jet carbs hahahahah Quote
Justintoxicated Posted May 31, 2006 Report Posted May 31, 2006 (edited) well the guy i got the pipes off of lives near me and i asked him what size jets he was running and he said when he put them on he never rejetted and i was like your lucky your bike didn't pop and he told me you need a pro to jet carbs hahahahah batoutofshell is selling plugs cheap in the for sale section. Personaly with K&N filter and lid removed from airbox, all stock, I ran a 320 yet for several years and never fowled a plug I think a 310 would have been spot on. But I'm jetted for glamis and it is alot hotter here and don't know your elevation. FMF has a jetting chart on their website. Hate to see you blow up your banshee with too small of jets. I also lowered the clip on the needle (raised the needle) one notch from stock (I htink I moved it from 3rd to 4th clip but I don't remember) Edited May 31, 2006 by Justintoxicated Quote
RILS Posted May 31, 2006 Report Posted May 31, 2006 Im running trinitys pipes with stock box and filter with the snorkel removed at abot the same elavation and temp wiyh a 280 and its perfect.27.5 pilot 4th slot on needle 1.5 out on air screw you could start from there and work ur way down Quote
BansheeMxer#45 Posted May 31, 2006 Report Posted May 31, 2006 when i bought my banshee it had fmf fatties and k&N filter with snorkle off. i was thinking of replaceing the lid with a outer wear lid. i dont know if he rejeted it but it seem to run good ive riding it for couple years now and raced it.if i put on the outer wear lid shold i rejet or should it be fine. does some one know what the stocks size jets are in . sorry to butt in but i think this is on the right topic Quote
