Hey guys i need your input on this one. I performed a search but got some mixed reviews. I just replaced my stock clutch with a tusk clutch and left the cushions in place. They all looked ok but the problem is with the clutch adjusted correctly my shee wants to creep forward with clutch lever pulled in. Should i remove the cushions and retry to see if it goes away. Will the cushions cause the clutch plates to hang up and allow it to creep forward with level pulled all the way in? Any help would be great.
I believe most aftermarket clutches call for those rubber cushions to get pitched. They are there to soften up the clutch engagement which is not really a good thing.
can you remove these cushons from an oem clutch, and how involved would this process be?
518588[/snapback]
Same work as clutch replacement: remove side cover and clutch hub, then remove the cushions as you get to them, between the fibers and steels. Then back together again.
