65983cobra Posted May 13, 2006 Report Posted May 13, 2006 i am having a problem with a rich codition at idle.has any one had this problem?problem started after i put on tors elim kit. i have fattys 280 mains 30 pilets and dynotune 6 clip needles on the #4 clip.tried to ajust floats to 22mm but problem still is there.could this be normal because it rides pretty good. Quote
batoutofshell Posted May 13, 2006 Report Posted May 13, 2006 go back down to 25 pilot thats what I did my plugs were browning real bad at idle till i went back. Quote
65983cobra Posted May 13, 2006 Author Report Posted May 13, 2006 i had the 25s in there and it was also doing it.before i put in the 30s.i could let it idle for a few and the plugs would be wet with fuel. Quote
batoutofshell Posted May 13, 2006 Report Posted May 13, 2006 well to tell you the truth banshee's aren't made to idle for long 2 minutes and I go you are supposed to blip the throttle and warm it up not let it set there and idle. How did you set your idle after you installed the kit. Quote
mnduner Posted May 13, 2006 Report Posted May 13, 2006 (edited) i had the 25s in there and it was also doing it.before i put in the 30s.i could let it idle for a few and the plugs would be wet with fuel. 515350[/snapback] wait so it was rich at idle with 25s so you try 30's???!! Edited May 13, 2006 by mnduner Quote
batoutofshell Posted May 13, 2006 Report Posted May 13, 2006 where are your air screws turned to Quote
65983cobra Posted May 15, 2006 Author Report Posted May 15, 2006 (edited) air screws 2.0 out.all this started after i put in the tors elim kit then i read on fmf web that they sudjest the 30s so i went with them and i cant say they made the condition wrost.but yes i still was rich with the 25s so ya i guess puting the 30s in dosnt make much sense.my buddy said that my reeds may be bad could that be true? Edited May 15, 2006 by 65983cobra Quote
dajogejr Posted May 15, 2006 Report Posted May 15, 2006 (edited) Put the 25's back in, start with the screw .5 turns out. Warm it up... Turn the screws out 1/4 to 1/2 turn at a time, wait 20 seconds for it to take effect. Stop when you have the highest idle...they're set. Then, set the idle screws accordingly, if needed. FMFs like fatter pilots...but, 30 is too much. Try the 25s and see how it goes...if you end up with less than .5 turns out...then go bigger to 27.5. As you probably know, 21mm is the correct height on stock carbs. Edited May 15, 2006 by dajogejr Quote
