cheezehead69 Posted May 9, 2006 Report Posted May 9, 2006 i just put a set of t-6 and a tors elimination kit on my stock shee. i run at about 3000 to 4000 feet above see level in all tempeture conditions in canada. i changed my main jet to a 190 and dident do anything else. the problem i have is it is using a lot of gas now. and when it idles it is fine at first but when i ride it for a while it idles really low. what should i do. Quote
Tim C Posted May 9, 2006 Report Posted May 9, 2006 Do you mean 290 main jets...........190's seems very lean - 200 is stock Quote
cheezehead69 Posted May 13, 2006 Author Report Posted May 13, 2006 the jet says 190 on the bottom of it. so i dont know what is going on. but i went from riding the same trail and having half or a quarter tank to and empty tank just being able to make it back. something is not right. i exspect it to eat more gas but not that much. Quote
batoutofshell Posted May 13, 2006 Report Posted May 13, 2006 what kind of carbs do you have sounds like 34-35 mm Quote
icecold_shee Posted May 15, 2006 Report Posted May 15, 2006 sound extremely lean to me, i think you should be around 270s mj Quote
cheezehead69 Posted May 15, 2006 Author Report Posted May 15, 2006 thats what i thought but i tyed 240s and it ran like ass. no power at all Quote
digger Posted May 23, 2006 Report Posted May 23, 2006 unless u like welded pistons i would get those 190's out of there!!!!! i have the same pipes and i'm running 320's and so are most other people, what type of air filter system u running, if u still have the air box maybee a 280 at the least!!! when u bought the pipes it should have come with 270's and 280's but i found them too lean.i would put in 300's and do a plug chop and go from there..... u'r plugs must be white now!!!! Quote
cudaz101 Posted May 23, 2006 Report Posted May 23, 2006 Something aint right...I bet if you pulled the choke all the way out at WOT the quad would pull a wheelie...heh Get that bike jetted even if you have to take it to a shop or your shee is gonna be a GRILLED SHEEEEZE Sammich... Brad Quote
cheezehead69 Posted May 23, 2006 Author Report Posted May 23, 2006 i think i will take it to the shop and have them jet it for me if they arnt going to charge me an arm and a leg. when i have it done i will let you know what is the deal. thanks for the help. Quote
trex banshee Posted May 24, 2006 Report Posted May 24, 2006 You are complaining about using a tank of gas in one day! Try going to alcohol tank of gas lasts about 20-30 minutes depending on how you ride it. Just kidding with ya but yeh your jetting does sound way off, better get her figured out before she goes! Quote
