So my Outerwears over my Pro Design foam filter is killing me. I had it on last weekend and suddenly my quad lost all power and wouldn't run right. I took it off and it ran great again. Obviously it was clogged up. So I went and cleaned it at home the best I could. Went to ride today and again it wouldn't run with it. I took it off and noticed it was still a bit clogged in some spots. How do you clean these things?
ac
ac
512784[/snapback]
i just clean mine after every ride with soap and water then i just spray it with an air hose to dry it out then let it sit over night so its really dry then i put them back on.... never had any problems with mine... good luck with it tho
Well, I ran it through the washer machine with my riding gear. I used some Spray N Wash on it. It seems much cleaner now. I can see through the whole thing now. I will try it again next weekend!
ac
  • 4 weeks later...
Well, I took it out for a ride and again it would just bog and never come on the power. When I slip the outerwears off it runs like a raped ape! It is very weird. I cannot believe how restrictive this outerwears could be!
ac
After several good rides I just clean both filter and outterwears.. Iam not sure if your supposed to but I use the same spray on the outterwears as you use on the filters to clean out the dirt and oil... Seems to work good, havn't had any problems yet.
RIPPEN
Same here :cheers::cheers:
RIPPEN
522324[/snapback]
clean it with gas or something thats a solvent
512819[/snapback]
careful. catch a solvent thats too caustic and youll need a new outerwear.
The filter looks super clean. I am going to run it without the outerwear until the filter is dirty and then clean everything. The filter I am using is a Uni 2 layer.
ac
I run a pro-desing plate with a K&N filter with outerwear and have not had any problems yet. I too clean mine after every ride. Use the same cleaner for air filter and outerwear.
