I bought some t-5's and got the toomey jet kit with 280 and 270 mains and nedles i read the directions that toomey gives you about what jet to pick and where the clip should be and i cant seem to get the thing to run correct it seems like its flooding bc the plug is dark. but then you start out it seems like itsnot getting enough gas or maybe its too much. When im in 1st gear and go to take off its almost dies out its i hammer on it but is im moving slow and get into is slow its ok but then i hit 2nd its got mild power then after about 3 sec she becomes a beast and has a ton of powerif i back out at all it dies but if i ease into it again its rips thru all gears
280 min and on forth notch is my setting i also have the 2-1 airfilter any suggestions
airbox lid no lid? pilot screw on side of carbs should be 2 turns out do you resinc the carbs, and you should be on the 3-4th notch down from the top
I do believe you are suppost to run high octane fuel with that bike with those domes 110 octane , did you resinc the carbs
508430[/snapback]
with the 2-1 filter you will have to jet higher. try a 300-320 and a 27.5 pilot. goodluck
:bolt:
:bolt:
508456[/snapback]
I didn't realize you had the foam twin that comes with the toomey pipes check what first said
Try turning the air screws in and then back them out a half turn......you can go up to 2.5 turns before they are no longer affective....D
