Adal2154
    2002 Stock with skin kit on it
Adal2154's Achievements
  1. how much for the swing arm and do you have the rear axle carrier? Thanks
  2. yeah do you have to split the case?
  3. hey guys just looking to have a heads up on what i should see when i take mine apart i was ridein yesterday and when i landed i missed my foot peg and came down pretty hard on the shifter now its stick in 3or4 gear will not down shift might up shift but didnt want to try that cuz i had to limp her home thanks
  4. no basically no lid it takes out the airbox yes they were i forgot i also have 22cc domes
  5. I bought some t-5's and got the toomey jet kit with 280 and 270 mains and nedles i read the directions that toomey gives you about what jet to pick and where the clip should be and i cant seem to get the thing to run correct it seems like its flooding bc the plug is dark. but then you start out it seems like itsnot getting enough gas or maybe its too much. When im in 1st gear and go to take off its almost dies out its i hammer on it but is im moving slow and get into is slow its ok but then i hit 2nd its got mild power then after about 3 sec she becomes a beast and has a ton of powerif i back out at all it dies but if i ease into it again its rips thru all gears 280 min and on forth notch is my setting i also have the 2-1 airfilter any suggestions
