2001 banshee with t-5s dynojet kit with 280 main. should i get dual clamp ons or i was told I could run a k&n air filter with the k&n airbox lid or what? I just want the best product that will ghive me the best performance? Thanks
508357[/snapback]
K&N clamp on filters without a doubt. Then try 330 mains. I'd also recommend going to size 30 pilots.
Also, you can buy a couple of K&N "prechargers" to slip over your clamp on fiters; they keep globs of mud from getting on your actual filter, and they add NO restriction whatsoever. They are almost like a really fine netting. They are kinda pricey though (about $20 a peice, so it will run $40)
Just take out the stock airbox completely. You will have to buy a bracket from www.rockeymountainatv.com for $15 though, which will hold your reserve antifreeze tank (which normally would mount to your airbox). Don't worry though, its a really simple install. We are talking 2 bolts, and you use the same bolts that are already on it :)
Good luck. Thank me later. It will have alot more power after doing this, trust me.
He is right about the k&n pods wouldn't trade them for any other kind, but to save money you could cut the back of the airbox off where the coolant bottle mounts and just use it like that or what he said and buy the mount.
your gonna have to rejet up 310-320 27.5 on the pilots
Listen to what he ^ said. I'd buy 300's through 330's for mains (they're cheap) and 27.5 piolots. Start with the 330's and work your way down till ir revs clean. I wouldn't bother with a 30 pilot. The 27.5 should do ya, hell with only pipes and filters you may be able to adjust your air screw with the 25's and be fine. It's all trial and error.
