My banshee only will run on the left cylinder and they both get good spark and gas, if i rev it up high the other one kicks in sometimes, I talked to a good mechanic and he said it needs a new topend and most likely its from pull starting it, he said alot of the times when you pull start them the topends will go. I dont see how it could need a rebuild i just did another compression test and both cylinders have 110 - 115 psi, if anyone knows anything about this please let me know thanx. :cheers:
sounds like you have a fouled plug. Take your carbs off too and clean and sync them as well. Clean your air filter too. Start with the simple stuff then work your way up.
I had a similar problem and I swapped the carbs and the problem swapped as well. So I rebuilt my carbs and now everything works fine.
I have also herd that a faulty cdi could do that as well.
