i had something like that happen to me. it was hard to start then rev high wouldnt turn off , had to hit the gas with the key off to bring it down. Mine was both pilot jets were clogged. so try cleaning the carbs . if that dont work check for an air leak. :cheers:
Ill pull the carbs but I was also wondering if the slides on the carbs are supposed to go all the way down if you look in at the airbox when the idle is turned completely down? Mine are still up a little bit and i also heard it could be because it is to lean, I have the needle set one notch leaner than stock
If you adjust the idle screws all the way down, no the slides won't bottom out. With it running get some carb cleaner and spray it around where the reeds and intakes are. If there is a difference in idle then you have an air leak which will make your bike idle high. Make sure your slides are opening and closing at the same time also.
