BLUE STREAK Posted March 22, 2006 Report Posted March 22, 2006 hey any one got any old rear tires they want to give away??? I am going to make ice tires so I dont need any tread as i will be stabing holes in them to put bolts thrue I would like these to hold air if not I will tube them. Quote
BLUE STREAK Posted March 22, 2006 Author Report Posted March 22, 2006 I am hear are you there ware are you at I might be able to get it shipped Quote
batoutofshell Posted March 22, 2006 Report Posted March 22, 2006 I think this guy says he is from Australia Quote
BLUE STREAK Posted March 22, 2006 Author Report Posted March 22, 2006 who is in australia I am in CANADA in alberta Quote
BLUE STREAK Posted March 23, 2006 Author Report Posted March 23, 2006 BUMP top of the pile now any one local Quote
Tim C Posted March 23, 2006 Report Posted March 23, 2006 (edited) Check with a local dealer that installs them - they probably have have some old ones laying around. If your puting snowmobile type studs in your tires go with a 4 or 6 ply tire because if not they will pull through. Use big washers and really tighten them up and they won't leak much air. Edited March 23, 2006 by Tim C Quote
BLUE STREAK Posted March 23, 2006 Author Report Posted March 23, 2006 thanks I was just going to use some 3/8 bolts and big washers and grind the end of the bolt to a point I am not shure how much bolt I should have stiking out past the nut I was thinking about an inch I have seen them do this in automotive tires it should work for me. Quote
Tim C Posted March 23, 2006 Report Posted March 23, 2006 thanks I was just going to use some 3/8 bolts and big washers and grind the end of the bolt to a point I am not shure how much bolt I should have stiking out past the nut I was thinking about an inch I have seen them do this in automotive tires it should work for me. 491569[/snapback] I did that a few years ago - I used 1 1/4" long bolts and fender washers on the inside and outside. They have to be really sharp for them to dig in. If you can get some carbide snowmobile studs they'd be better because they'd stay sharper Quote
BLUE STREAK Posted March 24, 2006 Author Report Posted March 24, 2006 These wont see to much Ice just a lot of hard pack snow and some deep powder. I suppose sand paddles would work good in the deep stuff or some really aggressive mud tires. Quote
