senoroms Posted March 16, 2006 Report Posted March 16, 2006 i dont know whats going on, when im on the gas it runs great, but the moment im off it dies, what can i do to fix this? Quote
banshee421twin Posted March 16, 2006 Report Posted March 16, 2006 It could be the tores. Mine needs a new one. But mine is really fucked up. u got to turn the air screws back and forth and keep kickin and then she will finelly start. Quote
bansheeryder_69 Posted March 16, 2006 Report Posted March 16, 2006 T.O.R.S. play with the nickel sized screws on top of the carbs Quote
. Posted March 16, 2006 Report Posted March 16, 2006 dont listen to either of them is your tors still hooked up? If so disconnect the grey clips that go into them on top of the carbs, and also disconnect the little black box thats in front of the fuel petcock under the tank It should idle after that Quote
senoroms Posted March 17, 2006 Author Report Posted March 17, 2006 im sorry i should have mentioned that i removed my tors long time ago, other than that i have clamp ons with now air box and the filters are clean and my outerwares are just washed. i want to get it running right before i go to glamis in two weeks. not cool when i cant idle! Quote
senoroms Posted March 17, 2006 Author Report Posted March 17, 2006 haha sorry guys one too many tonight i meant i have no air box any help is great thanks everyone Quote
greg_banshee Posted March 17, 2006 Report Posted March 17, 2006 take the carbs off .. clean them blow some air threw the jets & then put them back on and make sure ur slides are in right (groved side to air filters) and sync them. Quote
senoroms Posted April 14, 2006 Author Report Posted April 14, 2006 so i took them apart and clenaed then really good but nothing. it still turns off, the only thing it will idle for like 2 seconds more than before, another thing i noticed is that even with my air screws all the way in, the idle isnt affected. i dont know what to do, any hlep would be great, leaving to glamis in the morning, would be nice if i could have it fixed by then. thanks everyone Quote
Toytrk85 Posted April 14, 2006 Report Posted April 14, 2006 When was the last time it was rebuilt? Might wanna check compression. Back in the day (Which according to Dane Cook always fell on a Weds), my blaster had a similar problem where it would run great and as soon as I pulled in the clutch and let off the throttle it would stop running. Ended up needing a rebuild and then she ran great. Nick Quote
sheefreak Posted April 14, 2006 Report Posted April 14, 2006 Did you take the pilot jet out and blow air through it, or did you just take the bowls off and spray everthing down? Quote
suzuki0702 Posted April 14, 2006 Report Posted April 14, 2006 screw the idle screws in on the tors kit.........in idle up...out idle down... Quote
Mean4x4 Posted April 15, 2006 Report Posted April 15, 2006 I HAVE THE SAME F* ING PROBLEM AND DON'T KNOW WHAT TO DO!! Quote
senoroms Posted April 17, 2006 Author Report Posted April 17, 2006 "When was the last time it was rebuilt? Might wanna check compression. Back in the day (Which according to Dane Cook always fell on a Weds), my blaster had a similar problem where it would run great and as soon as I pulled in the clutch and let off the throttle it would stop running. Ended up needing a rebuild and then she ran great. Nick" well i couldnt fix it by this past weekend. as for rebuidling, its an 03 and i have never rebuild it, but i didnt think about that becuase every time i drag i win, even against lightly moded shees and im just piped and milled head. Ive been riding since i was young so i figured that had a lot to do with it, but alot of people after we drag say that my bike runs real good. i just cant get the damn thing to idle. "Did you take the pilot jet out and blow air through it, or did you just take the bowls off and spray everthing down?" as far as cleaning the carbs out, i just removed the bowls, and cleaned everything out that way, how would i get to the pilot? Quote
dajogejr Posted April 17, 2006 Report Posted April 17, 2006 (edited) Remove the bowl, remove the main and plastic splash gaurd around it. You'll see the little hole opposite side of the main from the needle and seat. You'll need a tiny flat head screwdriver to get it out. I used a micro screwdriver kit to remove mine. Get a thin strand of wire, any kind...speaker wire, etc. remove the pilot and clean the holes with that wire...that'll knock/brush any dirt off it that air won't. For Sanity's sake...a compression test since it's 3 years old and you drag race would be a good idea.... Edited April 17, 2006 by dajogejr Quote
