Hollister_Hitman Posted March 14, 2006 Report Posted March 14, 2006 (edited) I put on a new throttle cable but i don't recall if the 2 cables out of the tors connected with each other in the throttle cover vertically or horizontally. Can someone take a quick look at there bike under the gas tank and check? (If you don't know what i am talking about the throttle cables come out of the tors and connect with each other in a rubber cover but i dont know if the cover should be set up vertical so that one cable is above the other or horizontally so that they are side by side. The reason I ask this is because the cables slide out of the 2 into on 1 connection causing the tors to activate killing my bike Edited March 14, 2006 by Hollister_Hitman Quote
FasterThanU90 Posted March 14, 2006 Report Posted March 14, 2006 Just remove the TORS. 486745[/snapback] Exactly if ur gonna go out and spend the money on a thrott cable why get a TORS one Quote
Hollister_Hitman Posted March 14, 2006 Author Report Posted March 14, 2006 (edited) I already bought the cable and still have the tors. the tors is not the problem. the cable keeps coming out on the right side of the 2 into 1. All I need to know is if your bikes have the 2 into 1 vertical or horizontal. The throttle cable is sticking on the lip of the rubber piece that the two cables go into to. Edited March 14, 2006 by Hollister_Hitman Quote
Hollister_Hitman Posted March 14, 2006 Author Report Posted March 14, 2006 I am going to just glue that shit on so it stays in place Quote
DIRTMAN350 Posted March 14, 2006 Report Posted March 14, 2006 Mine is Horizontal. Just replaced my cable. Sill have the worthless tors set up. Hopefully not to long jeff at fast racing will remove it for me. Quote
Hollister_Hitman Posted March 15, 2006 Author Report Posted March 15, 2006 Thanks mine is vertical right now i am going to have to mess with it to get it to stay in the 2 into 1 Quote
