i bolted up the brake to where the 2 parts come up but what is that 3rd grooved peice for i even have a little peice that fits in ther  :shrugani:
484721[/snapback]
That little grooved piece locks in on your swinger. Your swinger should have a little tab welded on it that the little grooved piece locks the brake plate to. Is that what you are talking about? I just put mine on like 5 min ago. I can go take a pic for you if you need.
awwww :o r u serious that sucks now i have to take that snap ring off and move it over the mount but i dont think they gave me a screw for it either thanks for the info sure post up a pic red
Can sum1 post up a pic of theres the piece doesnt even fit on the little nub and is it supposed to be tapped to fit a screw becuase its flush
485097[/snapback]
Maybe this will help... if you want closer pics let me know. I think you can figure it out by the pic though.
think yah can get a close up sideview from the brake side thanks
Thank u so much that really helped alot the tab that comes off the swinger is to big for that little peice so m just gonna drill it out a little again thanks :cheers:
After alot of drilling,grinding and cussing this is how she turned out looks killer :headbang:0.0737.jpg
OMG I forgot how skinny the stock front suspension is. Ha Ha! Get some +2+1 a-arms next man, you will love it. Swinger looks awesome. Your frame looks a litle tweaked, you check to see if it was straight when you had it tore down?
- Jared
Yah that and a set of nice shocks is my next mod, yah it does look a little tweaked might just be the pic but i kno its bent at the top were it comes up for the rad. hopefully getting a new one soon both our shees have bent frames it blows. Oh and where the shock bolts to the swinger theres about a half inch of space left on the bolt any of yah also have this prob?
487055[/snapback]
Run down to your local parts place like ACE or soemthing and get some spacer pieces. Or you can just use washers. Just make sure it's tight in there, no movement of the bolt.
yah im just gonna go and get the right size bolt get sum rad. hoses while im ther also :cheers: thanks for the compliments bud ,actually i just relized isnt that bolt a special kind for the grease fitting?
