460yfz Posted February 28, 2006 Report Posted February 28, 2006 on v-force reeds do you have to use the big gaskets on the intake side or can you just use regular gaskets. I tore mine trying to put in new reeds. the big gaskets cover the little gap were the reed cages snap together and the regular gaskets don't. if I use regular gaskets I can see daylight around the cage were it snap together. Quote
bigboybanshee Posted February 28, 2006 Report Posted February 28, 2006 I used the stock gaskets with mine, no leaks so far Quote
ellison445 Posted February 28, 2006 Report Posted February 28, 2006 Same here! I used the stock gaskets with mine, no leaks so far 480178[/snapback] Quote
wacko2000 Posted February 28, 2006 Report Posted February 28, 2006 no problems so far with stock gaskets Quote
suzuki0702 Posted February 28, 2006 Report Posted February 28, 2006 no problems so far with stock gaskets 480248[/snapback] ditto Quote
