You said your dealership put the pipes on and jetted it for you?
You may need to go back and check that out. And make sure the choke crossover
tube, between the carbs, is in place. :shrugani:
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
Its most likely something as simple are your jetting! When it idles its your pilot jet and you air screw that are effecting the bike... If you put new plugs in it will it start back up? If so, its your jetting! Try turning your air screw out a little, it should be out at least 1.5 turns and maybe try a smaller pilot jet!
You can also check your compression, if its low, or uneven from side to side, it could be time for rings or you a fresh bore if you scuffed it!
If you put a few more details it will be easier to diagnose!
I just got some new plugs for it, and it made no difference, but I did make a discovery! It only happens when the choke is not on, so as soon as i push in the choke it starts crapping out, no matter how good you rev it, so its not the idle. There are some smart people on here I know you can help :)
Pull off the fuel line from the right side carb and see if there is sufficient flow. If thats not it, try unplugging the little black box above your left pipe under the gas tank and see how it runs with it unplugged.
Ok I talked to the macs. at work. forgot to check spark before I went to work, so they told me to replace the spark plugg.Ive got spark but still the left side is not fireing. Took the pipes off to make sure the pistens were going up and down they are. Took the gas line off to make sure i was getting gas I am. I think there may be a plugg in the carb somewhere. Im bring the carb intommorow and have it checked. Im almost 100% sure the problem is in the carb. Ill let you know tommorow.
i had the sme problem a couple years ago turnd out to be the coil it checked out ok but i still had the problem so i got one off ebay cheep just to see if it was the problem and i havent had trouble since.
476549[/snapback]
when the choke is on the right carb pulls fuel from the left side. if it's not getting fuel with the choke off then I would suggest first make sure your needle and seat isn't stuck,then try cleaning the carbs jets and passages and try again.
:bolt:
When I take out my plug after it stops running, it is soaked. My dad said it looks and smells like oil, and not the mixing kind :cry: He thinks that maybe the oil ring could be shot? How can I test for this? It was broken in proporly, and I have been using castor since new.
477621[/snapback]
2-strokes do not have oil rings like 4 strokes. the crank gets oiled from the premix.your plugs if there fouled should smell like your premix and gas.if your right side crank seal is bad the right cylinder can suck oil from the clutch side which is your trans oil. or if your cases are not sealed properly, either side can suck oil.
:bolt:
