i just got a set of trinity pipes from loboboy (THANKS) and they sure look sweet, but anyways i need some ideas on where to start setting up the carbs and shee! engine is case ported/cylinders ported by trinity, .060 bore, 700-800 foot elevation, airbox lid off, and boyseen reeds, any more questions just ask. would spacers do anything for me or just a waste?
now how to set up the shee, right now it has a 12 tooth front and stock rear sprocket, what should i go to to use the power of the shee, for mostly gravel and sand pits and woods trail riding(fast and hard/aggresive), 21/12/9 mudsharks for rear tires, i weigh around 200lbs.
loboboy gave me an idea where to start(thanks) but need a few more tips
i did do a search and came up with next to nothing.
thanks guys :cheers:
Edited by snowfoxsx
I tried a 13,14,and15 front and like the 15 the best. if your running stock carbs and are ported, I would start with a 370-390 main, and 27.5 pilot. call trinity and ask them for a baseline, they should be able to get you in the ballpark. :bolt:
  • 1 month later...
RNBRAD runs or had them.
he might be able to give you some advice.
i would say 27.5 pilot, 4th clip on the needle, 340 mains adn do some plug chops
