bigd1985 Posted February 7, 2006 Report Posted February 7, 2006 Is it bad for a banshee motor too idle for long time? Quote
crazywheelerman365 Posted February 7, 2006 Report Posted February 7, 2006 AAAAAAAA hmm ? How longs long time ? It could over heat , Its liquid cooled.. Quote
FIRST BANSHEE Posted February 7, 2006 Report Posted February 7, 2006 what do you mean by bad? your banshee will be mad at you and thats bad. Quote
sandrappy Posted February 7, 2006 Report Posted February 7, 2006 Is it bad for a banshee motor too idle for long time? 469707[/snapback] Well 2 strokes aren't real effiecent at an idle, such as the pipes and ports ect... aren't working like they should at that rpm. So what you get if you leave a 2 stroke idleing for a long time is that they will load up since they can't burn 100% of the fuel at an idle. Plus if it goes to long it will overheat from no air flow. Quote
bigd1985 Posted February 7, 2006 Author Report Posted February 7, 2006 (edited) thanks yall I washed it one day and ran it down the road to dry it off came back to the house I had a phone call went in and left it running for like 25min. Edited February 7, 2006 by bigd1985 Quote
banshee tuner Posted February 7, 2006 Report Posted February 7, 2006 Usually they will run hot or foul the plugs, but if you have not had a problem you probably wont. Quote
lonestar Posted February 8, 2006 Report Posted February 8, 2006 Is it bad for a banshee motor too idle for long time? 469707[/snapback] It will load up. It's not a four stroke. To much vibration for a 2 stroke to let it sit their idling for a long time without hitting the throttle every 10 sec or so. You have to hit the throttle to blow off the excess fuel off the needles at the carbs. So it won't load up. Quote
