Is it bad for a banshee motor too idle for long time?
469707[/snapback]
Well 2 strokes aren't real effiecent at an idle, such as the pipes and ports ect... aren't working like they should at that rpm. So what you get if you leave a 2 stroke idleing for a long time is that they will load up since they can't burn 100% of the fuel at an idle. Plus if it goes to long it will overheat from no air flow.
thanks yall I washed it one day and ran it down the road to dry it off came back to the house I had a phone call went in and left it running for like 25min.
Edited by bigd1985
469707[/snapback]
It will load up. It's not a four stroke. To much vibration for a 2 stroke to let it sit their idling for a long time without hitting the throttle every 10 sec or so. You have to hit the throttle to blow off the excess fuel off the needles at the carbs. So it won't load up.
