It really depends on your bike, and how it is set-up. You can't really take someeon elses setting and just throw it on your bike. What are some of your mods, and I'm sure some can help get you close.
Also it will depend on the weather. since it can vary quite a bit. what elevation are you running at now??
stock with pro circut pipes and a K&N
were should I be
and what needle poss. are you guys running
going there in 3 weeks
thanks steve  :cheers:
466041[/snapback]
Prolly lookin at a 27.5 pilot
Toomey Needle in 3rd clip
250ish on the main if you are running a lid, 290 without
Someone might get you closer, I've always run the K&N clamp on pods.
  • 2 weeks later...
466105[/snapback]
im now got some k&n clamp ons 290 mains?
where do i get toomy needles can i just use stock needles ?
and is the pilot where the main screws into or where is that?
thanks for the help guys :cheers:
472012[/snapback]
With the clamp-ons I would suspect you should be more near to 330 range. You can use the stock needles, it seems to be much more personal preference than anything else. I would say 3rd clip on the stock needle, 4th if you step up to the Dynojet (included with Toomey kit) needle. The pilot jet sits in the casting right next to the main jet. The plastic guard/guide piece that fits around the main, where the tab goes down into the carb, that is where you will find your pilot jet. I ran a 27.5 pilot at 1.75 turns, but recently went back to the 25 (stock) pilot w/.5 turns out on the air screw after installing my VForce3's and noticed significantly better throttle response than immediately after the VForce install with 27.5's. I run this setup at Horsfall (Coos Bay/North Bend) flawlessly.
that would be 3rd clip from the bottom so one showing from the top right?
472099[/snapback]
Third clip position down from the blunt end. That's one one slot showing on the pointed end.
where do you ride now......wher are you from?
I live in north west part of washington st
and what works there?
I dont know I havent had a banshee for five years this is a new project
what ever works in florence works here Im going there in april just trying to get organized.
472154[/snapback]
Edited by 2strokersteve
