jjfizzle51 Posted January 24, 2006 Report Posted January 24, 2006 hey all i have i did a compression test and its reading 125 wich is low since i have a noss head with 19 cc domes. but since its low could i run an advanced timing plate +4 i plan on a rebuild next winter, so when i do that ill lower it but for now can i do it on pump gas thanks for any help Quote
RNBRAD Posted January 24, 2006 Report Posted January 24, 2006 I don't think you will make it till next winter. I would get new pistons in there asap unless you at like 10,000 feet. Quote
banshee tuner Posted January 24, 2006 Report Posted January 24, 2006 How hard is your bike to crank and how does it run? Did you have the throttle wide open while doing the compression test. Quote
BigRed350x Posted January 24, 2006 Report Posted January 24, 2006 I don't think you will make it till next winter. I would get new pistons in there asap unless you at like 10,000 feet. 463728[/snapback] lol 125psi is the best you can get with stock head at 7500ft. You have a fresh rebuild according to this altitude. Quote
Cotton eyed Joe Posted January 24, 2006 Report Posted January 24, 2006 hey all i have i did a compression test and its reading 125 wich is low since i have a noss head with 19 cc domes. but since its low could i run an advanced timing plate +4 i plan on a rebuild next winter, so when i do that ill lower it but for now can i do it on pump gas thanks for any help 463709[/snapback] Shit...rebuild it. We're at about 4800 feet or so, and even with my shaved head its pushing about 155 PSI. You should be more than that even. I'm about 20CC's or so. You should be in the 160's I'm thinking. A rebuild aint hard right now where you're at. A rebuild is a real bitch when a ring breaks up at 8000rpm, on the backside of Sand Mountain, and chews the shit out of everything from your head to your crank and rod bearings. Quote
Shee-Male Posted January 24, 2006 Report Posted January 24, 2006 WERD!!, spend a little now or spend ALOT very soon!! Quote
jjfizzle51 Posted January 24, 2006 Author Report Posted January 24, 2006 How hard is your bike to crank and how does it run? Did you have the throttle wide open while doing the compression test. 463761[/snapback] it starts in 1-2 kicks very easy and yes i had the throttle open it was cold though i dont know if that makes a diffrence or not ok so what do i need to rebuild i need to know everything ill rebuild this year so i prevent any upcoming trobles and so i can rip on the dunes this year Quote
greg_banshee Posted January 24, 2006 Report Posted January 24, 2006 I'd do a rebuild, i'm at pretty much see level here in Nova Scotia (Canada) and my Shee has stock pistons in it & its a 99 only had one ring change, we checked it, it had 120psi a side just before summer ran Great all summer started 1st kick everytime ! now thats what i call reliablility ! haha and i don't putt around on it. but i am doing a rebuild this upcomming spring just before summer because i know i don't want shit to fly apart inside flying down a dirt road wide open haha & just like Shee-Male said ... "spend a little now or spend ALOT very soon" u can get a Wiseco Kit with all gaskets, pistons, rings, clips, wrisp pin bearings, etc everything needed for rebuild & then all u need is ur local machine shop or where ever ur gona get it boar'd/honed out at to do it then ur ready to go. Good luck. Quote
