jjfizzle51 Posted January 23, 2006 Report Posted January 23, 2006 hey can someone explain more on how to use the fly wheel puller in terms of stupic people like me. thanks i have every thing i need i just cant figure out how the puller works and how to get it off thanks for any help Quote
GYTWYPT Posted January 23, 2006 Report Posted January 23, 2006 unscrew the small piece. Thread the big part into your flywheel. Make sure you get plenty of thread into your flywheel. I believe this is reverse thread. Now thread the small piece back in if you took it all the way oiut tighten it down and then hit it with the impact. Quote
PUSH THE THROTTLE Posted January 23, 2006 Report Posted January 23, 2006 Take the nut off the end of the crank. Insert the puller into the flywheel and screw it in (it's reverse thread so lefty tighty) then crank the center of the puller into the puller (righty tighty) and with some force it should come loose. Quote
PUSH THE THROTTLE Posted January 23, 2006 Report Posted January 23, 2006 unscrew the small piece. Thread the big part into your flywheel. Make sure you get plenty of thread into your flywheel. I believe this is reverse thread. Now thread the small piece back in if you took it all the way oiut tighten it down and then hit it with the impact. 463649[/snapback] Damn you beat me Quote
GYTWYPT Posted January 23, 2006 Report Posted January 23, 2006 Take the nut off the end of the crank. Quote
jjfizzle51 Posted January 23, 2006 Author Report Posted January 23, 2006 hey thanks guys one smack with the impact wrench flew right off i read the clymers and they where saying it in that mechanical language i didnt under stand its on its way to boonman as we speek Quote
locogato11283 Posted January 23, 2006 Report Posted January 23, 2006 Oh yeah hes right take the nut out of the flywheel first. This will help alot It is threaded normal. 463660[/snapback] haha yea, might help if the nuts off huh? Quote
