3ban5shee0 Posted January 23, 2006 Report Posted January 23, 2006 what would happen if you put a cr 500 crank on a cr 250 performance wise Quote
locogato11283 Posted January 23, 2006 Report Posted January 23, 2006 what are you trying to accomplish here? the stroke of those cranks are not the same. cr500 is 79mm i believe and cr250 is around 72mm. if i remember right the crank bearings are the same tho... Quote
3ban5shee0 Posted January 24, 2006 Author Report Posted January 24, 2006 what are you trying to accomplish here? the stroke of those cranks are not the same. cr500 is 79mm i believe and cr250 is around 72mm. if i remember right the crank bearings are the same tho... 463688[/snapback] heres the story my buddy just got done putting together this bike and hes goin to the army, he told me he had a cr 500 crank in this cr 250 did some other stuff to it like pipe and that kind of stuff but he never jetted his bike for a pipe and he blew it up now he wants to sell it to me for 200 bucks its a cr 250 brand new plastics, pipe its and older cr like late 80 early 90s its a nice bike but its blown up Quote
locogato11283 Posted January 24, 2006 Report Posted January 24, 2006 ill buy it for 200 bucks...i dont know what to tell u on the motor. a builder really needs to look at it and see whats going on with it. Quote
3ban5shee0 Posted January 25, 2006 Author Report Posted January 25, 2006 what would it do it would preatty much be like a stroker kit right anyone no what difference power wise there would Quote
Robert Posted January 25, 2006 Report Posted January 25, 2006 what would it do it would preatty much be like a stroker kit right anyone no what difference power wise there would 464202[/snapback] What? Quote
3ban5shee0 Posted January 25, 2006 Author Report Posted January 25, 2006 What? 464213[/snapback] i asked if anyone new the advantages of having a 500 crank in a 250 what would it do Quote
woodro77 Posted January 25, 2006 Report Posted January 25, 2006 (edited) the difference would be the piston smashing the head,it wouldnt fit Edited January 25, 2006 by woodro77 Quote
iceman Posted January 25, 2006 Report Posted January 25, 2006 yeah unless he put a bigger cylinder on it. it wouldnt fit. Quote
slowpokebanshee Posted January 25, 2006 Report Posted January 25, 2006 if the crank has a 5mm longer stroke, than you would need a 5mm spacer plate to make it work. Quote
seb4lo Posted January 26, 2006 Report Posted January 26, 2006 if the crank has a 5mm longer stroke, than you would need a 5mm spacer plate to make it work. 464386[/snapback] a 2.5 mm spacer is enought Quote
