13th Grave Posted January 23, 2006 Report Posted January 23, 2006 I got a stator with an ajustable backing plate and was set at +5 degrees. I was wondering if this might have caused it to lean out? Now i'm in the market for new jugs,pistons, and crank used in good condition let me know what ya got and if this may have caused it to prevent this from happening in the future. Quote
BigRed350x Posted January 23, 2006 Report Posted January 23, 2006 I got a stator with an ajustable backing plate and was set at +5 degrees. I was wondering if this might have caused it to lean out? Now i'm in the market for new jugs,pistons, and crank used in good condition let me know what ya got and if this may have caused it to prevent this from happening in the future. 463243[/snapback] No, it wouldn't cause it to melt down. You have a problem with jetting. Even if you got all new stuff, you would probably still have the same problem again unless you fix your jetting. Quote
dawarriorman Posted January 23, 2006 Report Posted January 23, 2006 Or you didn't use high enough octane, and blew up due to detonation. Quote
13th Grave Posted January 23, 2006 Author Report Posted January 23, 2006 Thanks for the info I won't let that happen again. Still in the market for the parts listed above. Quote
fastbanshee4u Posted January 23, 2006 Report Posted January 23, 2006 I have a wiseco hot rod crank,thats been welded for added strength.I got a stroker now this is for sale .$150.oo including shipping . Quote
