Iam finaly going back together with the front end. Today I noticed a little bit of play where the steering arm conects to the spindals. The two allen held bolts are tached so I know you cant tighten them but Iam afraid maybe the threads are pullin out??? Both sides have a little play, but the left is a little more noticeable. Is this a common problem or what can be done to fix it if anything??? Thanks
RIPPEN
I'm not totally sure on what you are talking about. I don't have any plat at all in my front end, but i have aftermarket stuff on mine. I would just double check that everything is tight everywhere. If it is, I wouldn't really worry unless it gets worse. Are you talking about your tie-rod ends or what? I don't have allen head bolts anywhere on my front end, and nothing is tached so I don't know what you are talking about.
Edited by BigRed350x
In the Clymer book they are calling it the knuckle arm & knuckle arm assembly(pg266)... But they are sayin 88 and on the allens conecting the two are spot welded and not to try and sperate them. But I don't see where it says anything about it being loose at all or if so to replace it..
RIPPEN
The tack welds are just there to keep the bolt from backing out.
I would just grind the tacks off and check the threads, if they are pulling out you need a new spindle anyways unless the can be fixed. If they aren't pulling out put some red locktight on the bolt and retighten. :)
