FOUND OUT TODAY,THE JACKASS WHO HAD MY QUAD BEFORE ME WAS RUNNING A 12/45 GEARING WITH A 20 INCH TIRE. DOES ANYONE SEE A PROBLEM IF I GO TO A 15/40ISH? AS LONG AS THE MOTOR WILL PULL IT,I SHOULD GET ABOUT AN EXTRA 25MPH ON THE TOP END. WITH THE 15/40 WILL I BE ABLE TO RUN A STOCK 102 LENGTH CHAIN?
Edited by BANSHEEFIEND
461252[/snapback]
what mods do you have? when my engine was stock with fmf sst pipes i went to 15/41 and it pulled it just fine. after i had the engine ported i played with the gearing and i tried 15/40 with the stock chain so you should be able to run the stock length chain as well.
15/41 seems to be pretty common and a favorite of mine as well.
1 tooth on the front rufly translates to 3 on the rear.
