BANSHEEFIEND
Everything posted by BANSHEEFIEND
  1. Come on people, this is a great deal!
  2. Yes, it fits all years that are 1mm over and she is brand spanking new! If anyone is interested give me a call at 920-205-7704, ask for Evan.
  3. Bumpity bump, someone needs to blow their stuff up.
  4. I have a K141 piston kit from Wiseco, comes with .040" over forged pistons, rings, wrist pins, circlips, wrist pin bearings, and topend cometic gasket kit. Hell, it even comes with some stickers! I need money quick, so how about $135 takes it?
  5. All right, my attachment level for yahoo is 10 mb and the manual is 18.8mb. How can I get it to you guys who want it? I don't know computers that well.
  6. A little info on my story. I get t-5s, put them on, push shee in yard, go to work. Dad and friends come home, friends ask about the quad, dad doesn't notice new pipes, fires her up , spins around the yard and melts a hole in the left piston. That was a nice suprise when i got home. So he finaced the new motor build and i picked up some wisecos, 19cc trinity head, boyesen power reeds and a new k&n . I already had the 35mm single pwk so i am a little happier now. Almost ready to fire her up and i was wondering what i should start my jetting at. I am in Wisconsin, 750ft. elevation and it's about 20 degrees out now. One more final question. When first starting her, should i break it in, then jet it, or vice versa? Thanks for your help.
  7. Hey, just got my cd and i am trying to get out of all caps, bad habit. But, i went through the cd tonight and it was extremely informative and precise. It doesn't tell how to do huge port alterations, but more of a fluff and buff, sleeve matching, small port work that will clean everything up a little and make more power. Kinda figured that was how it was going to be. On the other hand, i now have a 278 page cd-version of my old manual (it was falling apart). So, if you want a copy of the porting and/or manual, give me an email and i will try to send it to you. Both are in adobe and the manual is 18.8mb and the porting is 523kb.
  8. WESW, YOU EVER DRIVE A BRENNER TANK? THEY ARE THE BEST IN THE BUSINESS, CUZ I MAKE THEM! CERTIFIED MIG AND TIG, STAINLESS, MILD, CROMOLY, ALUMINUM AND CARBON STEEL ARE MY SPECIALTIES. http://www.brennertank.com/
  9. I FOUND THIS CD ON EBAY AND FIGURED THAT I MIGHT AS WELL TRY IT FOR EIGHT BUCKS. ANYBODY HAVE ANY INFO ON IT? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...00907%26fvi%3D1
  10. http://www.mototassinari.com/features.php FINALLY FOUND OUT, THEY HAVE ADJUSTABLE TENSION, LOOKS LIKE THE 3'S FOR ME.
  11. ALL I WANTED WAS SOME ADVICE ON WHAT REEDS TO BUY, JESUS CHRIST.
  12. FOUND OUT TODAY,THE JACKASS WHO HAD MY QUAD BEFORE ME WAS RUNNING A 12/45 GEARING WITH A 20 INCH TIRE. DOES ANYONE SEE A PROBLEM IF I GO TO A 15/40ISH? AS LONG AS THE MOTOR WILL PULL IT,I SHOULD GET ABOUT AN EXTRA 25MPH ON THE TOP END. WITH THE 15/40 WILL I BE ABLE TO RUN A STOCK 102 LENGTH CHAIN?
  13. I WAS LOOKING AT THE GRR CARBON FIBER REED PETALS OR THE VFORCE 3'S, I THINK I READ SOMEWHERE THAT THE 3'S HAVE ADJUSTABLE TENSION? CORRECT?
  14. WHAT ARE SOME OF THE THINGS THAT I SHOULD LOOK FOR WHEN SELECTING SOME NEW REEDS? ARE THE BENEFITS OF CARBON FIBER ALL THAT GREAT? MY MOTOR HAS T5'S, 19 CC TRINTIY HEAD, WISECOS, AND A 35MM KEIHIN. ANY HELP IS APPRECIATED.
  15. ARE THE STOCK HEADLIGHTS 35 WATTS, IF SO, WHAT WOULD HAPPEN IF I CONNECTED TWO 55 WATT FOG LIGHTS IN PLACE OF THEM? WOULD IT BE TOO MUCH OF A DRAIN ON THE ELECTRICAL SYSTEM? OR, IF YOU HAVE A CHEAP ALTERNATIVE IDEA, LETS HEAR IT!
  16. BIGRED30X, I DIND'T FILL THE CYLINDERS WITH WATER. I JUST BOLTED THE HEAD TO A PIECES OF PLEXIGLASS, SEALED IT WITH CHAPSTICK, LEFT THE PLUG OUT, THEN USED A SYRINGE TO FILL TO THE BOTTOM OF THE SPARK PLUG HOLE.
  17. IN THE PROCESS OF REBUILDING, HAD A STOCK HEAD. I TRIED MY IDEA AND CAME OUT WITH ABOUT 19.5 C.C.S PER DOME. PUMP GAS COMPATIBLE?
  18. I HAVE AN OLD TRINTY RACING HEAD THAT CAME WITH MY BANSHEE WHEN I BOUGHT IT. IT DOESN'T HAVE THE INTERCHANGEABLE DOMES. WOULD I BE ABLE TO PUT A SPARK PLUG IN IT, FILL IT WITH WATER USING A SYRINGE, AND DO SOME QUICK MATH TOO FIGURE OUT THE C.C.S? ALSO, WHAT IS THE SMALLEST C.C.S THAT I COULD RUN ON 94 PUMP GAS?
  19. I LOVE THE LOOK OF RACE CUT FENDERS. I WAS JUST WONDERING, WHEN YOU ARE RIDING, DO YOU GET HIT WITH A LOT MORE OF DEBRIS(ROCKS,MUD,SNOW)?
  20. I KNOW THAT ATVRACING.COM SELLS THE KITS BUT THEY ARE 189.00 DOLLARS. I'LL START NEXT WEEK FOR YOU GUYS.
  21. ONE MORE QUESTION FOR TODAY. I AM PLANNING ON BUILDING MY OWN MINUS ONE SWINGER. ON AFTERMARKET SWINGERS WITH THE HONDA STYLE CARRIER, HOW DO YOU ADJUST THE CHAIN? I TRIED TO LOOK FOR A PICTURE BUT COULDN'T FIND A CLEAR ENOUGH ONE.
  22. DOES ANYONE WANT TO SEE A COMPLETE J-ARM TO A-ARM SWAP WITH PICTURES? I TWEAKED BOTH OF MY OLD UPPERS AND DECIDED IT WAS TIME TO DO IT. I HAVE ALREADY DONE THE LEFT SIDE AND COULD STEP BY STEP FOR THE RIGHT SIDE. PARTS, PRICES, DIMENSIONS OF BRACKETS AND EVERYTHING. I AM EIGHTTEEN AND HAVE BEEN WELDING AND FABBING SINCE I CAN REMEBER. HIT ME UP IF YOU WANT IT.
