i have a 1998 banshee,bored .20 over,cool head,proflo,and procircuit pipes,i will be doing the timing plate and the v force3 reeds is there a pipe thats going to make overall better power then the procircuits?
You could get some PT mids, or maybe a 2 into 1 if you are looking to shift your power to a lower rpm. But you really aren't going to get much of a gain by changing brands / styles. If you want a large power increase get your cylinders ported. That will be you next big gain. Shop around find a builder who is good at porting for the type of riding you do. What type of riding do you do? PC's are more of a top end pipe. Are you looking for more low end power, or just more?
Like ogre said. If your looking for more power, then porting. If your looking for a more all around power curve, then get some Pt mids....
t5s or cpi pipes wouldnt make a difference?
457365[/snapback]
possibly t5s but cpi are gonna be flowing a lot more on top. they are generally used for a drag pipe. id just stick with what u have now...and get some porting done...that will bethe best way to smooth out your power.
457365[/snapback]
Well what do you not like about the pc pipes? We can steer you better if you describe what you want or what you don't like now..
