Ultimateduner Posted January 5, 2006 Report Posted January 5, 2006 Alright I scrapped what extra cash I have. I have $350.00. What the most effective mod(s) that I can buy with this much money. On my banshee I already have Dune port (kenz cycle tech) Cpi inframe drag pipes Milled head (.20) bored cylinders Wiseco pistons and rings K&N airfiler (in airbox) Stock carbs (tors on) Any help is useful. Thanks Quote
iceman Posted January 5, 2006 Report Posted January 5, 2006 get the tors eliminator kit. shouldve done that a while ago. adjustable timing plate. those are two necessities. do you need tires? maybe some plastics or new graphics? or some bling? maybe some aftermarket lighting or a trail tech speedo? handlebars? reed system? theres a ton more. Quote
Ultimateduner Posted January 5, 2006 Author Report Posted January 5, 2006 (edited) Yo Iceman read my sig it just listed everything you just said. Also yeah iknow I need the tors off. I like to have performance parts the bling I'll get later. thanks. Edited January 5, 2006 by Ultimateduner Quote
2003LimitedBanshee Posted January 5, 2006 Report Posted January 5, 2006 VForce is friggin awesome. I found a brand new set on eBay for 199.99 + 10 shipping when I got mine. Agree, adjustable timing plate is good for the 35+ shipping from RS. So you're sitting about $250. I might go for some protection at that point. You could go with a Pro Design High Fow billet impellar, or invest in a good TM (or other if you prefer) case saver. Lots of guys say get rid of the TORS, but I say get rid of it when it starts causing you problems, which mine hasn't yet. Otherwise all you're gaining is some visual and space appeal, as a perfectly functioning TORS system will not limit performance. All of these would keep you right around the $350 total, and should be good for several HP (possibly as much as 5-6). Quote
FIRST BANSHEE Posted January 5, 2006 Report Posted January 5, 2006 with a dune port and cpi's, I would get carbs first, timing plate,lighten the flywheell and shift star mod from boonman. I think with your setup the most bang is going to come from carbs. Quote
pimpeinkc Posted January 5, 2006 Report Posted January 5, 2006 get a dyna fs ignition.. bout 300.. i love mine and there is no need for the timing plate.... or see if you can find a 2 into 1 carb,, i love mine, all i have is, t-5's, dyna, 2 into 1 with 35mm, cool head with 21cc domes. and rad valves. 48 hp 35 torque and it is easy to work on and reliable Quote
eehsnab2 Posted January 5, 2006 Report Posted January 5, 2006 Got to get of those tors for sure! You can mod your own timing plate for free with a dremel... Looking at what you got a would say (if your crank is welded) go for the carbs or v-force... both are good for a couple ponies... and send that flywheel and shift star to boonman while they are off. Quote
gbf4ever Posted January 5, 2006 Report Posted January 5, 2006 Hey, id probably go with the carbs, more performance and you wouldnt have to worry about tors anymore. Quote
mike23 Posted January 5, 2006 Report Posted January 5, 2006 definately bigger carbs. let that dune port open up Quote
wesw Posted January 5, 2006 Report Posted January 5, 2006 get a dyna fs ignition.. bout 300.. i love mine and there is no need for the timing plate.... or see if you can find a 2 into 1 carb,, i love mine, all i have is, t-5's, dyna, 2 into 1 with 35mm, cool head with 21cc domes. and rad valves. 48 hp 35 torque and it is easy to work on and reliable 455490[/snapback] i suggest some carbs also, and the dyna box didnt make any noticeable power on my bike more spark. get some used carbs adn maybe a v force 3 and you would be set Quote
Ultimateduner Posted January 8, 2006 Author Report Posted January 8, 2006 Carbs, Keihin 33mm pwk's. 455571[/snapback] I think I'll go with the Carbs. So do the rest of you think that 33mm would be the right size? Quote
iceman Posted January 8, 2006 Report Posted January 8, 2006 didnt read your sig. you could go with 33s, 34s, 35s. get whatever you can get the best deal on. Quote
rocketboy Posted January 8, 2006 Report Posted January 8, 2006 dual 33 pwk keihin carbs ,passionre sells them for a good price o n here Quote
