I Blew the top end on my shee. it was at .090. some ppl have told me not to go to .100 cause of overheating issues.
just wanted some advice on if that is true or not.
I've heard of people going to .100 over. But you're making your cylinder walls paper thin. I'm pretty sure .100 is the limit. When it blew, what happened to the actual cylinder walls? Even if you can put it back together with a .100 bore, I'd start looking for some new jugs/sleeves or possible a cub motor :drool: for next time...
453350[/snapback]
it did score the cylinder wall a little. i was looking into getting new sleeves but i do not know if i want to go backwards to stock sleeves or go with big bore sleeves. yeah i was looking at the cheetah monoblocks but dam they are expensive. i see big bore sleeves on ebay for 89.95 each. i was thinking of doin that and going with 68mm pistons. i just don't know what to do.
Might want to see how much it will cost to have the sleeves installed.Might buy a set of used stock cylinders.Shouldn't be hard to find.Alot of people have switched to cubs.
Getting sleeves installed will cost you big bucks, but your back to stock bore and have a several rebuilds left so in the long run is not a bad idea. Cost wise you will be better off buying another set of cylinders.
If you sleeve it you dont have to go back to stock. There are always big bore sleeve kits. The labor should be no different and I beleive you can still bore big bore kits 3 to 4 times for rebuilds. You will also have to go to big bore domes,if you have a cool head, or have your stocker chambered. Cubs do seem to be the way to go though If you got the cash.
its true when the sleeves are that thin the motor will run hotter quicker and it makes them unreliable.if you decide to resleeve your cylinders go with the standard sleeves rather than big bore sleeves because you will need either a coolhead with big bore domes or get a stock head modded.in addition unless you have ports and transfers redone and have the right pipes it won't run any better than if you go with standard bore sleeves.just installing big bore sleeves without the portwork can actually make it slower than a properly tuned stock bore.i'm sure there are a few builders on here that would be glad to discuss it with you and help you decide which way to go.my own personal preference is "passionre" on here.he is always willing to help wether you want him to do motor work or just want his oppinions and suggestions.you can call him also if ya like 918-232-3950
