ish
Everything posted by ish
  1. ish
    wanted Cylinders
    you too
  2. ish
    wanted Cylinders
    need a ste of cylinders for my banshee if it needs to be bored its not a problem as long as it isn't over .080 thanks
  3. it did score the cylinder wall a little. i was looking into getting new sleeves but i do not know if i want to go backwards to stock sleeves or go with big bore sleeves. yeah i was looking at the cheetah monoblocks but dam they are expensive. i see big bore sleeves on ebay for 89.95 each. i was thinking of doin that and going with 68mm pistons. i just don't know what to do.
  4. I Blew the top end on my shee. it was at .090. some ppl have told me not to go to .100 cause of overheating issues. just wanted some advice on if that is true or not.
  5. weren't they out there kicking ppl out on sunday and handing out tickets?
  6. ok elevation close to sea level in miami, fl. compression i don't know whatever will make it run good, i want primarily a trail bike and every now and then spank someone in a drag race.
  7. i bought a banshee in march blew it up in june and know getting ready to rebuild. it had 66mm pistons minor poirting and 21cc domes in a duncan power head. i am going with 66.25mm pistons might get vforce reeds or boysen and i was wondering what size domes( i was thinking 19 or 20cc) input please.
  8. that is correct title needed plus a fifty daollar permit for a year. a bunch of us are planning a group ride to ocala in nov. not sure what dates are but will keep you guys posted.
  9. thanks. well last night i finally figured out what size pistons i have in the thing. they are 66mm or .080 over. i was in shock cause the bike did not go that fast. so i beleive i only have 2 bores left till i have to re sleeve the cyl. correct? i found a set of wiesco .090 should i use that? i think it will be 66.25mm or should i just go to the max and make it 66.50mm?
  10. What kind would you all recommend. also if i go up .020 on the size do i have to open the head it is a cool head with domes. i know i need new domes.
  11. as he said above. that's what i did. and what do ya know i went thru the top end and now am going to bore and port new reeds and i already had a duncan power head on it with t-5's. it was running in the mid 80's before. i am a big guy. 260lbs.
  12. oh well i gues the only way to look at it is. when it gets fixed it will be a lot faster. and i am going to learn a lot.
  13. i don't know i bought the bike 2 months ago. how long does it take for something like this to happen?
  14. you do have it backwards. if you have more oil than gas your rich. less oil than gas=lean.
  15. it is brand new in the box never been used. has everything tors eliminator and all. looking for $55.00.
  16. we still ride there at night mostly but the days are numbered now that they are constructing houses across the canal. i was out there on monday night and wednesday night and yes in all that rain. it was fun but soon it will be no more.
  17. guys come visit atvmiaxtreme we had a problem and lost everything but we moved to a new server and have to start all over again.
  18. unfortunatly yes i do. it runs about 6 or 7 bucks a quart. good thing it takes 1.7 quarts
  19. i use the honda 2 stroke tranny oil in mines. it's red just like regular tranny oil.
  20. i was out there this sunday it was good. lots of ppl out there. parked by card sound made my way to the race track and back again did some muddin with the wifes 4x4. overall good time.
  21. he aint kidding about ridin every weekend. we will be at the humps on sundy
