ARE THE STOCK HEADLIGHTS 35 WATTS, IF SO, WHAT WOULD HAPPEN IF I CONNECTED TWO 55 WATT FOG LIGHTS IN PLACE OF THEM? WOULD IT BE TOO MUCH OF A DRAIN ON THE ELECTRICAL SYSTEM? OR, IF YOU HAVE A CHEAP ALTERNATIVE IDEA, LETS HEAR IT!
they may not be as bright, you can put 130w on there and they will be less bright but you won't hert the elec system.
I could be all wet, but I was under the impression that it could cause some damage to the electrical. You could swap for some PIAA bulbs, which will provide whiter light, at the stock wattage. Or you could upgade the stator to a RS and run BIG lights.
452968[/snapback]
From what I've heard (im' not an electrical engineer) putting an accessory that required MORE power output than your current stator is like creating a dead short across your stator terminals.
