hell yes theres no way u can udjust ur idle without em have u ran ur bike since getting the kit?
Guest nightmare
I think I have a drill tap and two idle screws laying around. Pm me if you need them and I will check to see if I still have them.
yea, u can ride with out an idle kit on board......you'd just be tapping that throttle every 1/2 second, which would get old really quick! :shootself: unless somehow u pull out the cables a lil from the carb tops and tape em. :confused:
It will work till you get the idle kit, you just have to keep it reved with the throttle or it will shut off when you let off the gas. You can adjust the carb tops and keep it running but it is not recommended because you loose your throttle freeplay.
451660[/snapback]
Exactly. well said.
