kermithills Posted November 24, 2005 Report Share Posted November 24, 2005 I think im gonna start racing motocross and what is the best mods to get.All I have right now are Pro Circuit pipes, K&N filter, and the ATV Power up kit. Any help please. Quote Link to comment Share on other sites More sharing options...
BansheeBoy17 Posted November 24, 2005 Report Share Posted November 24, 2005 If you want to be running smooth and fast I recommend shocks a-arms axle tires. I've got a set of YFZ450 shocks I am looking to get $200 shipped for. Quote Link to comment Share on other sites More sharing options...
Wallrat Posted November 24, 2005 Report Share Posted November 24, 2005 What's your budget? Quote Link to comment Share on other sites More sharing options...
kermithills Posted November 24, 2005 Author Report Share Posted November 24, 2005 Not very high..im 16 and about to get a part-time job now that football is over. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted November 24, 2005 Report Share Posted November 24, 2005 For cheap i would recommend a timing plate and advance the timing. Then a cool head for more cooling and compression. Then porting if you can afford it! Axle and shocks are also a good choice for mx. Quote Link to comment Share on other sites More sharing options...
macgillivary Posted November 24, 2005 Report Share Posted November 24, 2005 (edited) im on a budget too and heres my setup so far no name +4 axle i got off ebay shortened stock swingarm 8 inch blue labels with 18 inch turf tamers yfz shocks up front, eyeball +3+1 arms 19inch holeshots up front renthal bars DG nerfs dynoport 2 into 1 pipe and dual fmfs modquad head with 21 cc domes(could just shave your stock head) ported stock reed cages lightened flywheel, +7 timing motofast 2 into 1 carb setup with a 40mm lectron and my bike runs pretty good, i have a desert tank but thats cuz i can ride from my house to a track but its a long ways so i wanted that no porting done yet but soon enough so ya its not cheap to make a "budget" mx banshee i dont mean to discourage ya first tho get some shocks and widen out that bitch and make it hook up, worry about the power second, banshees have nuts even just with a pipe and filter Edited November 24, 2005 by macgillivary Quote Link to comment Share on other sites More sharing options...
decon Posted November 25, 2005 Report Share Posted November 25, 2005 you should get the suspension hooked up first before anything...that's most important...might need a good $1000+ , extended a-arms, front shocks, shortened stock swinger,rebuilt rear shock, extended axle, etc. Quote Link to comment Share on other sites More sharing options...
knight_ripper Posted November 25, 2005 Report Share Posted November 25, 2005 suspension suspension suspension. after a few races youll see what we mean. the banshee has suspension thats 15 years outta date. Once you widen it and soften her up, youll have a new bike. You will then be getting all that banshee power to the ground...instead of just spinnin in the air. but then again...Ur only 16. U gotta lotta shakin and bumpin and crashin to do.....have fun with what you got...go out there and race...its a blast. worry about modin her later. Quote Link to comment Share on other sites More sharing options...
Dmcbanshee Posted November 25, 2005 Report Share Posted November 25, 2005 A good MX have this mods....But tons of money... Good set of A-Arms +2+1 LT or not.. Durablue,RPM or Lsr axle Shortened swingarm -1 or -2 with Double Bearing Carrier Good set of front shocks and rear shock Torque mods on the motor (2 in 1 carbs,milled head or coolhead 20cc,MX porting) Good set of pipes ->your pro circuit are good 4 Klaw MX or Holeshot MX Razr MX 3 good MX tires With that mods your are in good way Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted November 25, 2005 Report Share Posted November 25, 2005 Don't forget about the G-force axle, it's a cheaper alternative to the others and it has a lifetime warranty. Quote Link to comment Share on other sites More sharing options...
gatesy Posted November 27, 2005 Report Share Posted November 27, 2005 I race mine stock, and believe me it hurts after ther race!! If you can try to get some good front shocks, you arms will thank you for it. Quote Link to comment Share on other sites More sharing options...
