Guest nightmare
I love my Pro Circuit pipes. They make good power. If the pipes are your only mod start with 280 mains. That is what i am running and should put you in the ballpark depending on your altitude. I'm at 700 feet.
  • 2 weeks later...
i got a 90 with pc plat. and clamp on uni`s at 240 and it screams
When I got my 99 it had pc plats, mild port, and proflow, jetting was 300 mains, pilots #27.5, needle in 3rd position. When I got my 99 it had a great mid hit, but seemed flat on bottom and top. So out came the 300's, in went 320's. Flat spot on top started to disapear. Out went the 320's, in went 330's. Ran even harder on top. Out went the 330' in went the 340's. Ran wicked hard. Don't have any 350's yet, but when I get them I'm trying them. My elevation is 650ft, temp was 80 degrees, [mixed my gas at 50:1 which tricks the jets into thinking they're bigger than they are]. So I'm running at 340 mains. Why in the world are people running such small main jets? If you are under 1000ft, there's no way you should be under 300, and thats with a closed air box. Open that box up, and you should be in the 350 to 330 range. But hey, if you don't want all the power your motor has to offer it's your buisness. :shootself:
Edited by midnite
DO U THINK I SHOULD GO WITH BIGGER JETS I DO MOST OF MY RIDIN BETWEEN 0-600FT. IN THAT RANGE GIVE OR TAKE THANKS
