Lucky ass's..where im from if I was seen on the road with my shee they would shoot me on spot  :blink:  maybe I sould move
435869[/snapback]
I did my time to get this assignment, I did 3 years in Minot North Dakota before I came here.
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
  • 5 months later...
You said it shut down when you were letting off the throttle. It can and has happened that a 2 stoke can sieze up if you are "coasting" it. If your rpms are up and you just let off the throttle and let it coast, its just getting fule from the pilot jet. This is why i personally will not chop the throttle to do a plug check on a 2 stroke. motor still turning fast+ no fuel input= rebuild time!
Edited by latheboy
513779[/snapback]
how do you check your jetting then latheboy?and what kind of carbs do you run that fuel can pass a closed slide from a pilot jet?
lets stop guessing at what happened and find out for sure ,your plugs and pistons will usually tell yo u what happened so history doesnt repeat itself.post u p a pic of the pistons and your plugs :cheers:
Edited by rocketboy
