yo im out in Glamis( :dance::cheers: )and i wanna go rip it up but i justed cleaned my air filters and i used sum of that K&N filter cleaner and that shyt is really foamy so i needed to use alot of water to clean it and were on empty in our warrior so to conserve water somejackbass decided that we should use the gray water so i did that and im pretty shure that it had sand in it so now theres a bunch of little bass peices of sand embedded in my filters i tried kleanin em the best could but there still sum in em it doesnt really look like its on the inside tho should i ride or replace em2morow?
Uh.... Keep a spare clean set hand in case you run into that problem again.
Never take some jackbass's advice.Always use you're own judgment.
You might be OK with grey water because all large particles of sand settled to the bottom.
(BansheeBrian, HQ interpreter)
Yo Dawg, you aint playin.that sand is some nasty shiznit foshizzle!! id go old skool on that filter azz yo! Get my hoes to cleen it,knoe what im sayin? Ait, be reprezentin banshees at glamis biatch!
