927 is probably the best oil available, Ive used it for over 20 years. Just make sure to keep your cans shaken before fueling(everytime) and if the cans sit for more than a week shake them extra good. It also helps to run your carbs dry after your done riding for the day, otherwise you will be extra rich on oil the next time you fire up. 40-1 is more than enough protection  with 927...Jim
430991[/snapback]
jim recomended it to me wihen i got his motor, it does seperate, and you should run the carbs dry, but it does work good.... not the cleanist burning oil on the market but maybe the best lube out there
my wife seems to think the others give a burning sensation when applied  :cheers:
431184[/snapback]
thats cause your putting it in the wrong hole :blink:
