racer714 Posted October 18, 2005 Report Posted October 18, 2005 I have a dynoport 2 into 1 and the front main pipe runs real hot all the way to the stinger, its even melted a couple of gaskets at the stinger, any input?? is it probably lean jetting? how about air screws???? Quote
bigboybanshee Posted October 18, 2005 Report Posted October 18, 2005 Well, honestly I would think that since your pushing two cylinder's exhaust through one pipe that it would definitely run hotter than normal, but if it's hot enough to melt gaskets, etc., it could be too lean as you were thinking. What do your plugs look like? Quote
racer714 Posted October 18, 2005 Author Report Posted October 18, 2005 hae to wait tilll sunday to do a high speed chop, otherwise they alomost look rich??!!!! Quote
bigboybanshee Posted October 18, 2005 Report Posted October 18, 2005 hmmmmm, interesting. Has it done this all along or did it just recently start feeling hotter than usual? Typically the bike will run a little cooler if the jetting is rich. Also, have the temperatures in your area been hotter than normal? Quote
racer714 Posted October 18, 2005 Author Report Posted October 18, 2005 seems like it s always been that way, I noticed the jet hot coating near the cylinders is starting to get kinda rough and brittle feeling also Quote
Shee-Male Posted October 19, 2005 Report Posted October 19, 2005 It might be that the timing is to retarded otherwise its a carb/jetting issue. Put a fresh set of plugs then see what they look like? Quote
2strokesmoke Posted October 19, 2005 Report Posted October 19, 2005 i have a motofast i live about 50 miles from you mine has been running a little warmer in the fall weather but not hot enough to melt gaskets but my pipe has always got pretty warm prob air fuel screw did you change gas or mixture mine is sensitive to any change lets ride sometime Quote
macgillivary Posted October 19, 2005 Report Posted October 19, 2005 maybe its just the pipe itself i got a 2 into 1 pipe and dual fmfs on slow trails my temp gauge can get close to 200 with the 2 into 1, but the fmfs always stay at the normal temp around 160-170, rarely will go up to 180 my jetting is on too i just play with my lectron and its done so maybe just these pipes are hotter but then again im measuring coolant not exhaust Quote
2twin350s Posted October 19, 2005 Report Posted October 19, 2005 i run a motofast 2 into 1 on both my shees. your main jets should be at least 240s. and that is if your less than 50 over on your bores. 250s will be good for 50 over on your bores. Quote
racer714 Posted October 19, 2005 Author Report Posted October 19, 2005 thanks guys , Im thinking my 220 main isnt cuttin iton top end, hey 2strokesmoke where do you live?? lets ride! Quote
2strokesmoke Posted October 19, 2005 Report Posted October 19, 2005 thanks guys , Im thinking my 220 main isnt cuttin iton top end, hey 2strokesmoke where do you live?? lets ride! 427597[/snapback] i live about 10 miles west of rockford i ride some woods we have and a place called ki tracks check out the website www.kitracksatv.com they have a mx track grass drag trails mud bog it is pretty cool there is about 7 of us 2 banshees a quad racer a blaster a 200x and dirt bikes let me know where you ride i have a trailer to travel and ride i live in lakesummerset davis il Quote
