i am in the begining stages of my rebuild.this is my first ever building a motor i have a yamaha manual i am using for this build.i can get a cylmer i need be?? all brand new trany bearings lubed with engine oil klots 2-stoke.it calls out for engine oil for bearing lube not gear oil is this o.k. thats what i did.i bought yamabond case sealer what is the proper whay to use this case sealer? also for lightweight lithium grease for seals does sil-glyde sound good it is found at (napa).what is the correct way to put the grease on(just on the back of the seal)or do i put it on the seal and lube the bearing?also do i still use engine oil on the outside of the seals or grease?should i also lube the complete crank with klots oil rods,bearingsinside the case just about everything in the motor. somebody help me please i have alot of money into this now that i really dont have i have one shot at getting this right!!!!.i bought the quad in march rode two hours and have not rod cents i was not going to rebuild the motor but i rode a banshee last weekened and it remind me why i bought a banshee in the begining its the greats quad i have ever rode thanks bill
Using 10w30 or 10w40 engine oil as a trans oil is fine, as is using any of the trans- specific "gear lube" oils available at the bike shop. Do not use hypoid or type gl-4 or gl-5 oil in the trans. The syl-glide will work fine on the crank seals, just put it in the area between the two seal lips on each seal. It's for seal protection on start-up until the seals get the lube they need from the oil-gas mixture they will be emersed in. Leave the outside of the seals clean and dry where they contact the case halves.
You will have the lower case half on the bench with the trans and crank laying in it waiting to receive the upper half. Be sure the crankshaft bearing locating "nubs" on the outside of the bearings are where they should be. The mating surfaces of the case halves should be degreased with an evaporative solvent such as brake cleaner on a clean rag. Then a thin layer of Yamabond 4 will be applied to the mating surfaces of the upperr case half. Very little is needed, but be sure to cover the entire mating surface. Bolt the two halves together and turn all the shafts to make sure there is no binding.
Good luck with it.
Jerry
what is gl-4 or gl-5.also you say i should not use any oil on the seal surfaces on the case halfs why what will happen if i do .i did not use anything like a 10w 30 i used actual 2 stroke pre-mix oil klots will that work just as good.
It's broken......you ruined it forever!
No, it should be ok I personally wouldnt use pre-mix in there but i dont see why it would hurt anything just make sure you use real gear oil when you get it built ready to start or as some guys use ATF :cheers:
Uh...drain the premix out of the tranny and put in some non-synthetic 10w-30. I use Castrol GTX.
The reason you don't get oil on the mating surfaces of the cases is because the yamabond won't stick there and you have a potential for a leak.
Get a Clymers. I can't believe you went this far without one. I wonder how many things you broke in the process.
Use punctuation CORRECTLY. You'll get a lot more responses when your posts aren't so difficult to read.
well one im not a english major!I have not even put the cases together yet.i just set the transmission in the bottom side of the cases . i have not put the crank in yet all i did was lube the bearings befor i set them in place for the transmission.ill try to do better next time with spelling.also im not talking about the yamabond im talking about the seal surface on the cases for the seals for the transmission and crank.
418865[/snapback]
[/quote I would double check everything before you put the top case back on. also check your shift forks and gears for wear.sounds like you you covered all your bases, now work on your english...
:rotflmao: I had no problem reading your post. Good luck
