Dinner Posted September 13, 2005 Report Posted September 13, 2005 Hey everyone.....went out tonight and cleaned the carbs, put it all back together, went to start it and now it wont start...could i have done something wrong?...any help is appriciated...thanks Quote
watkins Posted September 14, 2005 Report Posted September 14, 2005 (edited) Is the choke tube still on there? Edited September 14, 2005 by watkins Quote
stockridinshee Posted September 14, 2005 Report Posted September 14, 2005 what watkins said check the little black tube that goes from the right carb to the left, probably forgot to put it back on. Quote
race-a-holic Posted September 14, 2005 Report Posted September 14, 2005 If you have stock carbs,definitely check the black tube.Very easy to forget.Also when you put the slides back in the carbs,did you put them back in right.Make sure they went all the way down in the carbs.This can also be a problem. Quote
Dinner Posted September 15, 2005 Author Report Posted September 15, 2005 Yea i always put the black choke tube back on....throttle is in right...its weird after sitting for a bit it wont start, so i go tow it with my brothers truck...pop the clutch in gear, wont start...then kick if over after and it starts Quote
