Nope, won't fit. The 20 is height, 11 width and 10 is rim diameter. You have a rim that is 8" diameter. Both 8s and 10s are the most common size in the aftermarket, so you should be able to find some 20-10-8s for your bike no problem.
Edit: The t-9 and Doug .190 are comparable rims. The t-9 has cutouts at the wheel center, so has a bit more of a 'fancy' look.
Edited by ssanddemon
412693[/snapback]
He said he has a 10x8 rim, so I would think that is 10" diameter and 8" wide in which case it would fit no problem.
412822[/snapback]
I'd assume it's a 10" wide 8" diameter so it won't fit. If it were 10 dia and 8" wide why would you mount an 11" wide tire on that rim anyway?
412850[/snapback]
The question was if they will fit.... so if it is a 10" diameter rim then they will fit. If it is only an 8" diameter rim then it will not. As far why would you want to... I run 22-11-10 Turf Tamers on a 10x8 rim and they work great. If you put them on a 10x10 rim the rim edge sticks out so if you hit a rock or something it hits the rim, which not only looks like shit, it could bend the edge and cause a leak. On an 8" wide rim the edge of the rim is set in a little bit so rocks and things bounce off the tire and doesn't beat up the rim as much. Of course doing that you have more of a chance of cutting the sidewall of the tire. So it's kinda six of one half dozen of the other. But Ive been running Turf Tamers which I believe are only a 2 ply tire for three years... the tread is done so they ready to replace... but I have never had a leak since they were installed. I have friends who are bending rims all the time but I never have. :)
413226[/snapback]
That's cool and I agree if it's a 10" rim it'll fit. Just seems to me that an 11" wide tire is a little too wide for an 8" rim, that's all if it works and you like it then great. I run tamers too, I've got 22-11-8's, 20-10-9's and 18-11-8's that I switch depending on where I ride. How do you like the 10" diameter rims? Seems like they'd work well on a 22 but that's alot of rim for anything smaller.
413229[/snapback]
I like the 10" a friend of mine had 22-11-8's and the sidewalls seemed to roll a lot so he switched to 10" and likes them better.
