BlueBanshe03 Posted August 6, 2005 Report Posted August 6, 2005 I live at about 950ft above sea level and i ride alot of mountains, so would that mean i should use race gas with 20cc domes, if so would the 21cc domes work fine?? Quote
VinceDizzy Posted August 6, 2005 Report Posted August 6, 2005 It would be good to know what your engine mods are so I could figure if it will be even worth your while to run race fuel. Ill look up a compression chart for domes. Somebody here probably knows right off the top of their head. Quote
BlueBanshe03 Posted August 6, 2005 Author Report Posted August 6, 2005 As of right now i have Toomey T-5's on and very soon im buying the noss head, and then some v-force 2's Quote
locogato11283 Posted August 6, 2005 Report Posted August 6, 2005 pm dlnoss here on the site. he can get you setup with domes and a head if you need one. Quote
RNBRAD Posted August 6, 2005 Report Posted August 6, 2005 I live at about 950ft above sea level and i ride alot of mountains, so would that mean i should use race gas with 20cc domes, if so would the 21cc domes work fine?? 401683[/snapback] Yea you will be fine with premium unleaded with 20cc domes. If you ever ride at lower altitudes just do a 50/50 mix with race gas. Quote
dlnoss Posted August 7, 2005 Report Posted August 7, 2005 I agree. At 950' and above you should be fine with 20cc domes and premium pump gas. You might list your other mods to be sure that doesn't change the answer. -David Quote
